Cadillac_Jack
Oct 22, 2014Explorer
NinerBikes wrote:
If you have two matching 120W panels, those are each close to 7 amps each charge rate. Why even bother screwing with the 50 watt solar panel and it's measly 2.5 addtional amps, when you already have 14 amps? Get another matching 120W panel if you can, and sell the 50 watt panel.
120W panels for 89 AH group 27's AGM's is plenty, for most applications.
Next time when your replace the Group 27's Trojans, consider 6V T105's instead. Much, much, much easier to keep charged, they don't have the crappy acid to lead ratios that car type sized batteries do, so that the damn battery can fit under the hood without shorting out at the terminals.
Trojan should make a T-105 AGM Side terminal batteries for cars already, for no shorts.
When you match batteries, you should match panels also... seems to me just to be common sense.
Understood. Oddly enough I have already come to the same conclusion. I am going to concentrate on the two 120 watt panels. I am wiring them in series and running 8 gauge MC4 wire to the Rouge through a plumbing vent. This will decrease my wire run to well less than 10 feet.
From the charger to the batteries I only have a 24 inch run, and it will be 6 gauge fused before and after the charger.
Later on I will take down the 50 watt panel, and replace it with a 100 watt unit and use the same wire route to the second charger thus I will be gaining an additional 6 amps plus absolutely no combiner boxes or holes in my roof.
Unfortunately, I can no longer find the Evergreen 72 cell 120 watt panels, so I will have to build a second array.
As to the T 105s, already been down that road. They will not fit in my battery box. The Trojan 27 TMX was really the best I could do, and still have a fair amount of room to work on and water the batteries.
The Trojan group 27s that I have are 105 AH each. I should be sized pretty well with the two 120 watt panels in series. I bought a relatively cheap watering system from Amazon, and it works flawlessly.
I also have the remote meter for the Rouge. Very exited about this setup.
Thanks for all the replies.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
