Roger10378
Dec 25, 2015Explorer II
naturist wrote:
Soap pods are not water, but they do contain water. Since the lowest temperature it is possible to lower the freezing point of water to by adding "stuff" is 0°F, you might get away without a problem as long as it stayed warmer, but if it goes below zero, you might have a mess.
Where did you get the idea that 0 deg. F is the coldest it can get. The water based antifreeze in you cars won't freeze till -35 or so depending on the concentration. I don't know what the freezing point of soap pods is (but I would think it would be way below zero because there is very little water) and I doubt you will be able to figure it out in a household freezer. To be safe buy them after you get out of the cold weather or keep them warm till you get south.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
