schlep1967
May 23, 2016Nomad
ford truck guy wrote:
When I am unhooking my super glide ,this is what I do .
chock the camper wheels
raise the landing gear
get in truck and backup to get the slack OFF the kingpin and set E-brake
get out and pull handle with ease every time
+1
Take a minute and really look at the pin and the hitch. The pin resemble an upside down "T". When the pin goes into the hitch the jaw then wraps around the thin part of the "T". So when hitched you have a wide surface both below and above the jaw. That way it can't bounce up out of the jaw. So what happens when you try to lift the trailer off the plate is you pinch the jaw between the lower wide surface and the upper plate.
Also you will notice that when pulling the movable jaw is what you are pulling against. With pressure against this piece it is impossible to pull the latch to release the jaw.
Chock the trailer wheels. Raise the trailer enough to take most of the weight off the truck. Put the truck in reverse and just ease back enough to put the pin against the front of the hitch. Set the parking brake. Put the truck in Park (in that order). And you will now be able to release the hitch. There should be no banging back and forth.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
