schlep1967
May 23, 2016Nomad
I personally do not use grease. I use a product called slip plate. You should be able to get it at NAPA Auto parts. Google it. It is an aerosol can. It is basically spray graphite. It goes on wet and dries quickly. Since it is dry it will not collect dirt and sand that could end up causing damage. And you are much less likely to end up with it on your clothes like grease.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
