schlep1967
May 24, 2016Nomad
dcgoodrich50 wrote:
I guess I do things a little different as once the trailer is in position and the wheels chocked, I immediately pull the release. 9 out of ten times it releases. If not, I simply put the truck in reverse, and without even hitting the gas, just let the tranny take the pressure off the kingpin. I then raise the trailer until it just barely clears the plate, clear the cables, and pull forward. 11 years with my Pullrite #3300 SuperGlide, and this has always worked.
Different pullrites may have different instructions. Mine definitely says do not lift the trailer off the plate.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
