CJW8
May 24, 2016Explorer
Me thinks you may be raising it too much. On mine, I lower the front landing gear until there is a slight gap, then I raise them (lowering the pin) just until the gap closes. I then pull the release handle. If it won't pull, I put the truck in neutral to take the pressure off of the pin. This usually happens when I have backed into a spot.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
