SoundGuy wrote:
... This technique does work, so much so that I had to add a light to my pump circuit so I'd know when the pump was running.
SYes, PEX pipes transfer the vibration. But the sound of the actual pump doesn't disappear with soft piping or sandwiching the foam under the pump. Like I said, it was pretty loud when I was holding it in my hands, disconnected from trailer floor. Don't remember the exact name now, but it is not Shurflo Revolution - some earlier 3 chamber Shurflo.
Back to the Flowjet with by-pass. The consensus seems to be that it doesn't need expansion tank to smooth the flow, but the by-pass is a no substitute for expansion tank either. You open the faucet a trickle, or flush the toilet - and the pump with by-pass (and without exp. tank) will go online immediately. I hope I got it right.
