obscenic
Dec 18, 2016Explorer
Trackrig wrote:
The two most common accumulator tanks are the littler plastic one and the larger steel one. I installed the larger one in my MH and all has been fine with it. I'll install another larger one in my TT in the spring when it's warm outside again.
With the larger ones you have to set the air pressure in the bladder. In the four years it's been installed, I've had to re-pressure the bladder once. Does the smaller one also need to be pressurized and did you do it?
Bill
Small plastic. Do you also use a bypass pump? My accumulator was factory pressurized and I checked the pressure and it's good. You can feel it working, you get a nice steady stream when the pump turns off.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
