obscenic's avatar
obscenic
Pump hammering after installing accumulator
I have a class B with a nearly new pump (Shurflo 4008, installed about 1 year ago). Even with the bypass, running the sink caused pump cycling to a degree though not as bad as it was with the old 3 chamber pump. I decided to add a small accumulator to smooth out the flow and reduce cycling; even though I know the bypass and the accumulator both are designed to accomplish the same thing.
Now, when running the sink (even at very low output) the water flow is smooth and the pump cycles normally and acceptably. However, occasionally when you turn the tap off, the pump hammers on and off for about 1-1.5 seconds quite loudly. It probably cycles 7 or 8 times until it hits pressure and shuts off.
I'm wondering what I could do to correct this, and if anyone can assess what the cause may be. Thanks in advance!
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
