I have been playing with an issue on my trailer recently where water pressure seems to be low or the pump runs a long time priming the line. I figured the issue is a leak before the pump that was let...
Seems to me you're trying to fix a problem that doesn't, or shouldn't exist, meaning that if your pump / hose setup uses the ubiquitous Shurflo fittings there's no reason at all for them to leak or require the use of any teflon tape or even back off if hand tightened properly. I'd suspect your system is leaking air elsewhere as it doesn't take much to prevent the pump from doing it's job ... as an example, are you sure the city water inlet check valve isn't leaking air? :@
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
