rwbradleyExplorerJun 08, 2015Pump Leak?I have been playing with an issue on my trailer recently where water pressure seems to be low or the pump runs a long time priming the line. I figured the issue is a leak before the pump that was let...Show More
Old-BiscuitExplorer IIIJun 08, 2015A city water check valve leaking with DRIP water........is it wet around city water connection?ANYTHING downstream (after) of pump discharge will be under pressure and will leak water OUT not suck air IN.Any air being sucked in comes from pump suction ie: between fresh water tank and pump.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
Related ContentWater PumpFunny water pump leakBigfoot leveling pump leakAC/Heat Pump LeakingLippert faucet leaks, replaced with Moen
