wolfe10
Nov 11, 2013Explorer
Actually, you WANT air at the top of the water heater. When you heat water (or virtually anything else) it EXPANDS. Water is non-compressible. If no air at the top, the overpressure will cause the pop-off valve to leak.
And, if the on/off bothers you (as it does me), fit an ACCUMULATOR.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
