jauguston
Nov 11, 2013Explorer
For those of you that suggest adding a accumulator to your water system consider this. I replaced our low output water pump with a 7+ GPM/60 PSI Shur-Flo and its instructions stated if the water system has a accumulator it should be disconnected. Recommending adding one would not be advisable in all cases.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
