camperdave
Aug 17, 2020Explorer
Good question about where the water will come from! I've wondered the same, we usually run off the tank/pump only, but lately I've been using the city water hook up more.
I still keep the fresh water tank full, and turn on the pump when showering (other times, who cares if the water pressure is low?). I have not tracked how much water comes out of the tank, I assume it's a split of both depending on the pressure differential.
and smarty, you are correct your pump will not help you out if the fresh water tank is empty.
