wa8yxm
Aug 19, 2020Explorer III
Ok some background.
Motor homes have one or two water pumps (The one I saw with two also came with a price tag.. that had two COMMAS in it. like 1,500,000.00 dollars)
The owner said if you turn 'em both on it will knock your hat off in the shower (He's a "Country-Cowboy-Gospel-Performer by the way. Actually rather good I bought one of his CDs)
Most pumps are set at 45-55 PSI
Many parks are as well but some parks. well 120 PSI is not unheard of (Common where I park winters)
So you use a regulator.
Regulators come in basically 4.2 flavors
1.1 A cylinder about 3/4 inch Brass or plastic male hose fitting on one end female on the other may or may not be "Adjustable"
1.2 Like the above but with eithr "Wings" on the body or a bright (usually) plastic GRIP on the female end. this is often called "HIgh Volume" or "High Flow"
These are junk do not purchase them. Oh I use one for a very low-flow project but they are not useful They do Reulate but 1GPM if you are lucky on the high-flow Not good for a shower.
2: Sur-Flow (A Watts Company) This one is sometimes built into an RV. or you can get an "inline" the actualy regulator is identical in either case.
New I give it about a 9.. I can take a shower with only slight loss of pressure. Not sure how they hold up as they age but appear a kit may be possible.
Valterra Adjustable ... This one gets good reviews from others. I've never used. I recommend it for consideration.
"Whole House "inline" by Watts or Zurin (have used both) The two I have are 3/4 Inch (Turns out that's cheaper than 1/2 at least the Zurin) with garden hose adapters threaded into one and sweated on the other.
These are solid 10's when new. but like the joke about Bo Dereck aging over time 9-8-7-6 But in both cases rebuild kits exist.
What is a 10.. I set my Zurin for 50 PSI static (no flow) Opened the shower full and the needle on the Gague.. Frozen in place at 50 PSI.
So. where does this get us with the pump.
I strongly recommend a regulator (See 120 PSI) if yours is a "low flow" fill the on board tank and when you need High-Flow (IE Shower) Turn it on.
What I do (I no longer use a regulator for house water even at the 120 PSI park)
I use a low flow for a MISTER I have.. 1/2 gallon per hour is well within the regulator's capacity :)
But for all other use The high pressure park also got hit with high chlorine a few years back.. Water tasted of bleach. So I hit on the idea of filling my 80 gallon fresh tank and letting it set for a few minutes (The book (Caring for fish tanks) says it don't take long) and sure enough the book was right.
Then I discovered (After my wife died) I can go up to 4 weeks on 80 gallons. So since summers I stay at two parks , one with better water, I tank up at the good park before I leave. 2 weeks in the not so good water park, and back Tank up again after a few days and just before I leave.
Same with Dumping.. I dump in the Good water park
WHY? 1/2 the hookups and unhookups I don't even mess with hoses at the bad water park.
