ajriding's avatar
ajriding
Explorer II
Feb 04, 2020
Pumping out of a water jug
I have two old Tuco 5 gallon water jugs that have an internal hose (removable) and a threaded small cap where the water can be pumped out of the jug when hooked to a pump.
If looks like about a garden hose size thread.
There is a big opening for pouring and filling.
I cannot find more jugs that have this internal hose feature.
If I knew exactly if other jugs had the same threads then I could move the hose as needed, but really am looking for a jug that can be used with a pump.
Are these out there anymore?
  • I believe you can legally make small quantities of beer or wine legally in the US. Beer for sure they sell kits to do it.
  • agesilaus wrote:
    Carboy with threaded connector
    They are called carboys and since these are for labs the prices are outrageous. That's because real labs have contracts with the lab supply companies and the labs pay deeply discounted prices. But the 12V pump is the best idea
    Here is what a Carboy really is (can't resist having this memory flash seeing "carboys" mentioned)
    https://en.wikipedia.org/wiki/Carboy
    I remember these from home-brewing days making beer. I used the one-bottle method, which meant the beer sat in the bottles for a month or so with the gunk (forget the correct term) settling until the beer in the upper part of the bottle was clear. Then you had to pour it carefully tipping into a tipped glass so not get any gunk in your glass of beer.
    The "two-bottle" method avoided that, so you didn't get any gunk in the beer bottles. My method meant you could not take it over to your friend's place or it would re-mix bumping down the road. It did not "travel well". :)
    My friend made wine and used carboys for that. The idea was it took six months to make wine. So he got apples from my trees in the Fall, and we drank his wine at Xmas. We declared the six months was up :)
    Only useful for RVers in the USA in the ? Ozarks ? dodging the "Revenoors" AFAIK. ( No fear of those guys in Nova Scotia back in the day )
  • Carboy with threaded connector
  • Good ideas…
    I have a regular RV pump. I have a 10 gallon RV water tank, very small, and two 5 gallon jugs with the siphon (that the word).
    I want 40 gallons…, but will make do.
    I have a tiny 12v pump too, probably like that $20 mentioned, and maybe it would be easiest to transfer water to the 10 gallon tank, or maybe just move the siphon hose around to the full jugs.
    I imagine each trip requires different amts of water, so not always taking 40 gallons as I would boondocking many days in the where-to-find-water western states. It is a small space so not having a 40 gallon tank eat up space is a huge bonus during times I do not need that much water. I also like the option to move jugs to the truck or outside to make more space in camper.
    I will be happy with 20 gallons though, and with jugs it is easier to find places to fill than trying to run a hose to an RV.
    If I can find good jugs then one option is to not mount any RV tanks, but just use the portable ones as needed.
    I'm still in the think out loud phase so feel free to have opinions
  • jdc1's avatar
    jdc1
    Explorer II
    You can get a cheap 12v pump from Amazon for less than $20. You won't have to lift or hold the water jug.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    You can "Home brew"
    Take a plastic barbed fitting attach clear tubing to the "in the tank" part and drill a hole in the cap. Drop a washer (Stainless) over the fitting (I'd suggest 1/2 inch IPT on the barb fitting and washer) then shove it throught the same size hole in cap. Now drop on a 2nd washer Brass on this side Then screw on a brass hose coupler (your choice of gender) and job done. Cap or plug the hose coupler for transport You may want a small vent hole or just losen the cap.
  • As an alternative perhaps, one of these works with all sorts of containers. I have used it to fill the FW tank in the RV from a bucket sitting on the ground. Inverter to run the drill.
    I did notice the MSW inverter ran the drill slowly, but it was still enough to get the water up into the trailer. A PSW would be a little faster.
    https://www.canadiantire.ca/en/pdp/mastercraft-drill-pump-kit-0543802p.0543802.html?gclid=EAIaIQobChMIxoXFr_S45wIVAtVkCh1zpAL6EAQYAiABEgKQJPD_BwE&gclsrc=aw.ds#store=366
  • I was looking at how to transfer water last year. I have Aqua-tainer style jugs, which I do recommend, but they don't have the siphon hose, which I think you are referring to. On Amazon I found several submersible pumps that I think would have fit through the opening on the jugs, when the entire cap was removed.
    I didn't end up going that way, so I can't say much more about the pumps than to just suggest you take a look.
    I ended up making a shelf to support a jug, laying on its side, and gravity draining into our fill port. I can still lift a 7 gal jug, just don't care to hold it up for a long time while it drains, and that's where the shelf comes in.
    The threads for the spout on the Aqua-tainer are garden hose size, which also happens to be 3/4" NPT. I'm sure a creative mind could figure out how to create a siphon hose using a plastic pipe nipple and a piece of hose passing through. So that's another idea for you.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 02, 2025
