BFL13
May 22, 2018Explorer II
It depends on the location of the vents. If there is a lower "in" and a higher "out" then you pull in at the bottom and push out at the top. If the unit is horizontal with a vent at each end, you have a choice which is push and which is pull as long as they aren't the
same :)
OK if the question is for horizontal and you have one fan for one end, do you suck or blow? Then I am not sure. My converters are like that, but I need to check what they do.
The ones I have worked with are easy to mount the other way around, but reversing the wires as mentioned earlier is also a way.
same :)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
