Gdetrailer
May 22, 2018Explorer III
BFL13 wrote:
It depends on the location of the vents. If there is a lower "in" and a higher "out" then you pull in at the bottom and push out at the top. If the unit is horizontal with a vent at each end, you have a choice which is push and which is pull as long as they aren't the
same :)
OK if the question is for horizontal and you have one fan for one end, do you suck or blow? Then I am not sure. My converters are like that, but I need to check what they do.
The ones I have worked with are easy to mount the other way around, but reversing the wires as mentioned earlier is also a way.
Hmm.. COMPUTER CASE TYPE DC "muffin" fans are not "reversible" via the wiring. Do so at your own risk :E
Computer case type muffin fans are BRUSHLESS MOTORS AND ARE ELECTRONICALLY DRIVEN. The drivers are not designed to have the polarity reversed and will go up in smoke.
Now if you are talking BRUSH type DC motors, then yes you can reverse by changing polarity.. However brush type DC motors are much less efficient and put out tons of RFI noise from brush arcs.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
