MEXICOWANDERER
May 22, 2018Explorer
Specifically I am trying to determine Delta T pressure inside and outside the chamber. The higher the differential the better (obviously). The chamber is 1-1/2' x 1-1/4' x 2-1/2' tall. The emitting thermal element will be mounted on the deck inside. I am considering an 80 mm circulating fan. The emitter has an integral fan.
I used push-pull fans on the Hyperwatt power supply and even the toroids remained very near to ambient exterior at 56 amperes continuous. A highly modified Megawatt.
The current exercise is on a 130 ampere Meanwell RSP-1500-15
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
