landyacht318
May 22, 2018Explorer
My experience with many different computer fans says if there is to be resistance to airflow, better that resistance be in front of the fan, rather than behind it.
The blades trying to scavenge air through resistance makes them much less effective, and louder.
High static pressure rating is achieved most effectively, by increased rpm.
Since you enjoy Dual ball bearing fans, Delta makes some top quality fans some of which can turn at obscene rpms.
I have a delta PFB0912uhe, a 92 MM fan, on a voltage bucker which shaves a volt off the top. Still so powerful that loss is of no concern, and i can reduce fan speed to silent via a 10K ohm remote pot.
They have very powerful 80Mm fans too.
http://www.delta.com.tw/product/cp/dcfans/download/pdf/PFB/PFB80x80x38mm.pdf
138CFM and 51MM H20 and 9000 rpm 65DB
https://www.amazon.com/Delta-23-8038-01-Ball-Bearing-Cooling/dp/B009I0CG64/ref=sr_1_2?s=electronics&ie=UTF8&qid=1527039721&sr=1-2&keywords=PFB0812DHE
That Somnabeech is a air moving machine.
The blades in front of the impeller concentrate the airflow.
My 92MM fan column of air spreads only to 10 inches diameter at 3 feet.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
