Gdetrailer
May 23, 2018Explorer III
BFL13 wrote:Gdetrailer wrote:BFL13 wrote:
It depends on the location of the vents. If there is a lower "in" and a higher "out" then you pull in at the bottom and push out at the top. If the unit is horizontal with a vent at each end, you have a choice which is push and which is pull as long as they aren't the
same :)
OK if the question is for horizontal and you have one fan for one end, do you suck or blow? Then I am not sure. My converters are like that, but I need to check what they do.
The ones I have worked with are easy to mount the other way around, but reversing the wires as mentioned earlier is also a way.
Hmm.. COMPUTER CASE TYPE DC "muffin" fans are not "reversible" via the wiring. Do so at your own risk :E
Computer case type muffin fans are BRUSHLESS MOTORS AND ARE ELECTRONICALLY DRIVEN. The drivers are not designed to have the polarity reversed and will go up in smoke.
Now if you are talking BRUSH type DC motors, then yes you can reverse by changing polarity.. However brush type DC motors are much less efficient and put out tons of RFI noise from brush arcs.
OK thanks for the correction. I mounted mine the other way around and left the wiring as is. I got the reverse wiring idea from up-thread (wrong!) I know my RV ceiling vent fans run backwards it you swap the wires--in fact one is supposed to push or pull--you can choose by its switch.
Standard "RV" fans found in ceiling vents and range hoods are run of the mill low cost brush type motors which can be reversed via wiring. Easy to spot those since the motor sticks way out from the fan blades.
"Muffin" fans name comes from the flat axial motor design which computer fans use and the motor does not stick out of the fan case.
Many years ago, I used to have a handful of used original 120V Muffin fans from Mainframes, they really had the brand name of Muffin on them. Eventually sold them at a Hamfest. They worked great but too noisy for me.
The Muffin name is one of those things now days that a brand name is used to generically identify a type of design.
I changed out my RV vent fan with a nice 4" computer case fan, very quiet, uses much less energy and moves much more air.
I would also agree with a few of the comments, find larger fans which run at lower RPMS, something like 2800-3400 RPM can be rather quiet.. 4500-6000 RPMs fans are loud and will get real annoying real fast.
Most decent computer fans you can lookup the manufacturers model numbers and get the CFM, RPM, DB specs.
Some may even list static pressures it can operate in..
Static pressure IS what the OP is really needing since that determines how well the fan can push or pull air with restrictions.
HERE is a PDF from Sunon which has a lot of good info plus specs on their fans.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
