FloridaFlyer86's avatar
Apr 14, 2014
PV solar system charging voltage low
Ok solar gurus - I am experiencing low voltage with my PV solar system. The charging voltage will not go above 12.8V. I'm using a Morningstar SS-6L-12V SunSaver controller (2nd gen) with 4 new Crown 6V 220 AH batteries wired series/parallel for a 440 AH 12V system, and a single 95 watt PV panel (astroenergy). The measured open circuit voltage from the panel is 20.3V. The SS-6L-12V should be charging at 14.4 volts for flooded batteries. The green charging light is on. I’m using a TriMetric TM-2025-RV battery monitor and I do get positive current flow (5A) but I’m going to end up stratifying my batteries if I don’t get the voltage up. I also have measured the voltage at the terminals of the controller and also see 12.8V there. (at rest battery voltage is 12.5V.) This is a new system (so all connections are new and clean, with dielectric grease and proper torque) but the components have been used before… over a year ago so my memory is hazy but I’m pretty sure I saw 14.4V before. I’m not too concerned about any wiring being undersized, I went overkill to avoid that possibility.
So I have an email in to Morningstar but I have no idea how long they might take to respond… and I might just have something stupid going on, unrelated to the controller. Any help is appreciated, hopefully I haven’t left anything out.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 13, 2026
