BFL13 wrote:
Snowman9000 wrote:
I contend that you should use at least 17v, if not higher, for your voltage drop calculations. A quick run through that calculator shows that 50' of 10 gauge wire will present a voltage well into the 15's at the controller. Good enough for PWM in my book! Maybe the open circuit voltage of 22.x is really the one to use.
I only have a 100w portable kit, 6.x amps. I used 12-2 low voltage landscape wire from the big box hardware store. With Anderson Powerpole connectors at all junctions. You'd probably need to upgrade your tires to haul around all that 6 gauge wire. :)
The voltage on the wire from panel to controller with a "12v" is the battery voltage at the time. The IV curve V is battery voltage.
With "24v" the panel to MPPT controller (when in Bulk) wire is at Vmp maybe 30v, but the wire from controller to battery is "12v" battery voltage. I don't know what the "24v" panel voltage would be when the MPPT controller is in PWM.
If you have 17.7Vmp, 22.4Voc panels, and your wiring loses 1.5v, you've still got plenty of headroom with PWM to supply what the battery will take. Right, or not?
