Snowman9000's avatar
Snowman9000
PWM controller with no float
OK, I have a Morningstar Sunsaver 20a PWM controller. It's not the current generation, which is a 3-stage unit. It's basically a 2-stage without the float stage. It delivers full amps till the target voltage is met, then it tapers the amps. When the batteries are full, it delivers full voltage, say 14.4 at 77F, but very low amps. I've not let it stay connected to see how low the amps go, but let's say they go down to a fraction of an amp for 200 AH of batteries.
Given enough time, will this boil the batteries? When I read Morningstar's publications about PWM, it sounds as if, at such low rates of charge, the pulses would be spread out enough to inhibit gassing. I've emailed their tech desk, but I wonder if any of you have experience with same.
