BFL13
Jul 24, 2015Explorer II
Now I have some internet time, I will continue to solve this ! :)
EDIT--see crewzer in this link below--re "duty cycle" etc--some here mentioned that earlier too, but he does a calculation
http://forum.solar-electric.com/forum/solar-electric-power-wind-power-balance-of-system/advanced-solar-electric-technical-forum/1164-c40-or-ts45-max-voltage-question
Saw the video in the OP--Mr Wiz has an accent! :) My question, not answered yet, was if the panel voltage was taken on the other side of that disconnect fuse and so might the that fuse have a high R creating that 17v? So that is why I asked it the voltage could be taken right at the controller terminals to see if there it is at battery voltage.
So far I found this answer in a forum where somebody asked about his C40 by someone who has one (no link, sorry)
"If the battery is full, the C40 stops charging and the PV array drifts to it's Voc point. When the battery is low, it connects to the PV, and pulls the PV voltage down to the battery voltage."
It was also mentioned that it is PWM and not MPPT by somebody who wished it were MPPT.
I also found a schematic but it is hard to read (the layout one has a zoom though)
http://www.waghornswood.net.nz/Manuals/Solar_power/Controllers/Trace_engineering_Xantrex/index.html
In this strange conversation, it opne where the guy says the CC drops it to 14, but not clear. The staff answer next is clear enough.
http://www.solarpaneltalk.com/showthread.php?12899-Xantrex-C60-PWM-CC-input-voltage-up-to-55V
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
