jseyfert3's avatar
jseyfert3
Xantrex Truecharge2 Reliability?
Hello all,
New member here with a 2015 Rockwood 2306 that we picked up June of 2018. We're upgrading from the terrible group 24 battery to a set of two Trojan T-105 batteries. I'm looking for a suitable charger for them. As I understand, this means take to 14.4 volts (bulk), hold at 14.4 V until the current drops to small percent of capacity (absorption). At this point the battery is full, and you either switch to float at 13.5 V or stop charging entirely. Equalization is done roughly monthly for a couple of hours at 16 volts. Ideally, all stages of charging are temperature compensated as well.
Basically, the only one I've found so far that actually does a proper temp compensated charge, with a proper equalization, is the Xantrex TrueCharge2. This will charge at full current to 14.4 volts, then hold until current drops to 5% of charger rating, then to go float, if desired, at 13.5 volts. Also has equalization mode at 16 volts. Has temp equalization with battery temp sensor, or three settings via button if not.
I've read some things concerning reliability of the TrueCharge2. Anyone familiar with any reliability concerns on it? Any other temp compensated chargers that do a proper charge profile I should consider?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
