BFL13
Jul 24, 2015Explorer II
MrWizard wrote:
i think, the only time my array is at VOC is IF I disconnect it from the controller, VOC is 22+ volts, i have never read that with the panels connected
Correct. The mystery here is if you get higher than battery voltage plus line loss at the array side of the controller when the controller is in Bulk. So to be clear, do you get that 17v in Bulk?
If you only get that 17 or 18v in Float or perhaps in the timed one hour at Vabs before it goes to Float, then it could be that meter averaging thing for the duty cycle.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
