BFL13
Jul 26, 2015Explorer II
Thanks Mr Wiz! At least we now know the C40 is indeed a normal series PWM.
I didn't really know about that PWM duty cycle effect when the controller is controlling, so I learned about that. :)
As you know, you are really taking a beating on the controller to battery path, but it is a complex situation to do anything about in the MH.
Usually means you will undercharge the batts wrt the intended voltages you set, but you also do the weekly "cure" with the VEC1093. Mex says not to worry too much about the AGMs not getting quite the "right" voltages.
Battery voltage sense wire?
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28484577.cfm
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
