BFL13
Jul 26, 2015Explorer II
In this case the actual battery vs panel voltages are not what count.
"Battery voltage" should be "controller out voltage" (about I volt higher than battery) to compare with "panel voltage" and that should be "controller input voltage" There is a standing 0.4 loss across the controller itself.
So looking at the earlier morning results, IMO the controller is doing its proper closed switch thing and then it gets very close to the Bulk setting 14.5v at controller output and it should then start its one hour of Absorption before dropping to Float.
With Mr Wiz' battery draws during the afternoon it might not drop to Float? If so, what do you call it after the hour at Absorption is up?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
