LScamper
Jul 27, 2015Explorer
red31 wrote:
"PWM or 16.62-13.92 * 16.10a = 43.47 Watts going to heat up controller?
"16.62
controller out
13.92v"
Think about 43.47 Watts going to heat up controller. If you have a series PWM controller and it is in the off state the panel voltage is at V open circuit as you have said. But in the off state the current is zero! With zero current there is no power dissipation (P = V*I) to heat the controller.
Also if you have a shunt type PWM controller and if is in the off state the panel voltage is zero, the panel output is shorted by the controller. With zero voltage there is no power dissipation (P=V*I) to heat the controller. OK there will be a small voltage drop across the shunt switch so there will be a small amount of power dissipation with a shunt controller.
"16.62
controller out
13.92v"
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
