opnspaces
Jan 03, 2014Navigator III
I'm with the bottle jack crowd. If your RV is like most, the leaf springs run under the axles. Just put the jack under the axle on that flat plate that is all the leaf springs are sitting and jack it up. Then slide a jack stand under and as near to the bottle jack as possible. Now lower the axle until it firmly contacts the jack stand.
Personally at this point I would leave the bottle jack holding the majority of the weight and the jack stand is there in case the bottle jack fails.
Do one wheel at a time an don't forget to loosen the lugs while the tire is still on the ground.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
