time2roll
Jan 25, 2015Nomad
For generator use I would stay away from a 50 amp cord.
Go with a 30 amp or make your own 40 amp.
While #10 is fine go #8 EPDM 3 conductor right here at $4 per foot.
http://www.stayonline.com/soow-600-volt-bulk-wire.aspx
Get your 30a twist lock to go direct into the Honda Companion.
http://www.stayonline.com/detail.aspx?id=6774
Then get the needed 50 amp end to connect to the existing cord or the connector on the side of the RV.
http://www.marinco.com/en/6364crn
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
