joelyn's avatar
joelyn
question about 12 v led lighting?? (UPDATE)
going to install the strip of led lights under my awning and have them wired to my outside porch light.
looking at the picture below, do i cut the black wire (right there) with the adapter connection (number 1 arrow ) so that i can connect to the light socket with the red and black wire (arrow number 2)to power the lights.
and if so does it matter which wire is connected to which wire?
thanks
hope u understand and if not let me know what u need.
number 1 arrow is to the left u can just see the tip of it, not sure why it didn't show it or why its a little blurry.
2nd pic is much better
i have a RGB control box which that plug (Number 1) gets plugged into which also has the IR remote control on it which all fits into the existing outside porch light. this all came in a kit.
thats good about the wiring, I will just see which one or way lights them up.
just one last question, that plug that i want to use and cut i DON'T HAVE TO INCLUDE THAT BLACK ROUND THING THAT IS JUST BEFORE THE PLUG I WANT TO CUT. LOOKS LIKE MAYBE some type of transformer.
thanks again for the help
OK, TRIED TO hook up the lights in the trailer. i cut the barrel plug off like in the picture and wired it to the porch light adapter plug as shown in the picture. all ready to throw the switch and when i did only the blue colored lights lit up and the remote does not function with any button on it. can not even turn them off or change colors.
so i must have power but thats it.
any suggestions??????????????
  • If you get the rewires reverse polarity, no workee, no harm no foul. Switch the 12-volt wires and boiing the lights come on. Many of those power bricks are not 12.0 volt output. Try 12.3 to 12.8
    Why not just wire in direct into the rig 12 volt system and add a 12 volt LED dimmer which has an off switch?
