Dashonthedash's avatar
Dec 09, 2015
Question about coach battery posts
I've found a good source for a pair of new Interstate GC2-XHD coach batteries at a good price. They will replace my current Deka GC15's. The question I have concerns the post type. I can get either the high profile (UT) post or the low profile (UTL) post. Both are in stock. They are identical in all other aspects, the same price, and either one will fit. The high profile posts have the connection bolt atop an SAE-type post, the low profile just the bolt. The low profile will use a little bit less space, the high profile will make access to the posts (for measuring, charging, etc) a little bit easier. I have enough clearance. Which should I get?
  • Thanks, gbopp, I actually thought that the low post was primarily for confined battery installations, but I also noticed that there have been forum posts by people who have purchased the low version.
  • My vote is for the high post, it makes access, measuring & charging a little easier. Easier is good.
    What would you do with the little space you save with the low post?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
