tryingitout's avatar
tryingitout
Question about converter
I have a World Friendship converter, and it seems to be reducing my 12 volt power. I will explain, when plugged into shore power it works fine putting out 13.6. When I unplung and run on battery, I have the problem. I have 2-115 amp hour battery's, reading 12 volts with my tester. When I turn on some lights and the pump runs the battery's stay at 12 volts, but at the converter it is down to 10 volt. The pump won't shut off because it is down to 9 volts. I disconnected the converter from the distribution panel, and it helps considerately the voltage comes back up to 11. I have no problem buying a new converter, if that is the problem. I just don't want to buy one and still have the problem. Any insight into what could be happening?
This is a 2006 living quarter horse trailer that I just bought, I think it spent most of its time plugged into a/c at horse shows
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
