grizzzman
Apr 25, 2016Explorer
phemens wrote:
Hi,
I have a pre-existing 30A solar controller with 3 12v panels (2 x 80, 1 x 130) feeding 4 T-125's. I added a new 250w 24v panel hooked up to a separate Solar30 controller. Both controllers wire in to a cable run to the batteries (~ 6 feet, 00 gauge). I'm seeing the expected amperage out of the pre-existing array (290 watts giving me ~ 5 amps roughly). However, the reading I'm getting off the Solar30 with the 250w 24v panel is only showing 0.8 amps? Wiring from the panel to the controller is about 12 feet @ 14 gauge, which should be ok.
Any ideas why I'd see such a difference?
Old solar array (290w 12v) --> Rogue 30 --\__________ T125's
New solar array (250w 24v) --> Solar30 ---/
If I rember correctly the solar30 is a 12 volt controller. What did out pay for this controller? well it will do a 24 battery system. I assume you are running a 12 volt system?
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
