beemerphile1
May 23, 2016Explorer
darsben wrote:
Since when you are plugged into shore power your 12 volt stuff (fridge etc) is run of a built in converter my initial guess is that the wire you have that tripped the breaker went to the converter that supplies 12 volt to the rig. Now you are running only off battery.
My guess bad converter
My thoughts also but I wouldn't go so far as to say the converter is bad. At this point it is unknown why the wire is shorted to ground, further research is needed.
Put a meter on the battery and you will probably find there is no charge going into the battery with that wire disconnected.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
