Dmbaker07's avatar
Dmbaker07
Question about house battery's
Hello everyone, I had the camper out for the first trip of the season and ran into a few electrical issues. First many outlets did not work, I found that a breaker was tripped but tripped instantly if flipped back on. Since it had 2 hot wires going into it, I tried each one separately and found that 1 caused it and the other had no problems. After this everything worked, I am just not sure what that wire was feeding since I cannot find anything off now and it was marked "general purpose:. The issue I still have and possibly unrelated was low power. Even when I am plugged into shore power, if my furnace kicked on, I would get a Lowe power alarm on the refrigerator and my lights would be extremely dim. Even if I switched to LP for the refrigerator it would not work unless I started the motorhome. I am hoping it is just a bad house battery, but would that have this effect even when plugged in to shore power? I had it tested at a parts store on the way home and it did say replace ( had 330 CCA rated for 600). The battery is 4 years old. Any input would be greatly appreciated
  • If you have a battery charger put it on the battery and charge it up.
    I agree that you need to find out what the problem is with the mystery wire.
  • The fact that you have a battery rated in CCA would mean a hybrid deep cycle/starting battery and not a true deep cycle battery. You will either need some knowledge about 12 V systems and a hand held meter or hire a technician to diagnose your problems.
    The problem with the doubled circuit could be a 120V issue or converter related but we don't know if the wire you removed is the circuit for the converter. Again, a meter and how to test for continuity is necessary.
  • darsben wrote:
    Since when you are plugged into shore power your 12 volt stuff (fridge etc) is run of a built in converter my initial guess is that the wire you have that tripped the breaker went to the converter that supplies 12 volt to the rig. Now you are running only off battery.
    My guess bad converter
    My thoughts also but I wouldn't go so far as to say the converter is bad. At this point it is unknown why the wire is shorted to ground, further research is needed.
    Put a meter on the battery and you will probably find there is no charge going into the battery with that wire disconnected.
  • Since when you are plugged into shore power your 12 volt stuff (fridge etc) is run of a built in converter my initial guess is that the wire you have that tripped the breaker went to the converter that supplies 12 volt to the rig. Now you are running only off battery.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
