pianotuna
Oct 29, 2015Nomad III
85 watts for the laptop equates to 8.5 amps @ 12 volts. The existing batteries are compromised in some way.
Check to see if the electrolyte is covering the plates. If it is not add just enough distilled water to do so then fully charge them--say for 168 hours at 13.2 volts.
After they are fully charged then disconnect them from the RV and do an equalization charge at 16 volts. Then check the specific gravity in each cell using a temperature compensated gauge.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
