ScottG
Dec 12, 2018Nomad
Mbiviano wrote:
I run mine consistently with the door closed and haven't had a problem. Haven't noticed heat build up either. I'm not sure how it could be expected that you would leave the door open at all times when running it.
It would not surprise me if the "engineers" didn't even consider heat. Most of the units I have seen had no way to run the firdges while traveling so naturally we wondered if it would work closed up or was even inteded to be run that way. Sounds like it works ok.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
