noteven
Nov 22, 2021Explorer III
otrfun wrote:noteven wrote:Outside of input/output connections and a trigger input to turn the unit off and on, there are no other connections or sensors on a Renogy dc to dc charger that would relay any info about an alternator's condition, load or output rating. I've briefly read through the 25a/40a Redarc manual and I believe this is also true for the Redarc.
. . . DC DC probably has some control around overloading the alternator.
Especially REDARC equipment- Australia has been a decade or two ahead of north North America using on board charging equipment in campers and trucks operating in remote regions.
There are a number of ways to program the *output* of a dc to dc charger to protect and properly charge the battery; however, very few options (if any) to regulate the *input* load to protect the alternator (the only exception is the half-power mode on the Renogy).
This is why choosing a dc to dc charger with the proper current rating is important (in respect to alternator load).
I think otr is correct ^. I have a Renogy on the project shelf. It is a 40amp model. The literature states input amps are 60amps at 40amps output.
High output alternators are not super expensive if your oem one kicks the bucket..
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
