wa8yxm
Jan 20, 2018Explorer III
The easiest way to seal the vents may well be to remove the outside and vent assembly and cut a piece of think plywood or paneling and install it and install the vent OVER it.. Personally I'd make it so you can open and close the vents if you wish In the summer it may work better with vents open.. Or not
You can also lay foam insulation on the inside of the ply. Like foam rubber or styrafoam.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
