Denny___Jami
Jan 21, 2018Explorer
If you are going to install a residential refrigerator in a rv there are a few things you will have to keep in mind.
1st don't use one that uses the case for condenser, it's the type that the case gets warm when running. In most cases there isn't enough free air movement to cool the unit.
2nd If you use one with a external condenser up the back it will need air movement in the summer by keeping the external vents open but in extremely cold weather they will have to be blocked off.
3rd If you use the type that has the condenser under the unit with a blower motor to draw room air into the condenser and exhausts it back into the room just block off both vents. This is the type that is used when you order a rv with a residential frig.
Denny
Denny
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
