tinstartrvlr's avatar
tinstartrvlr
Question about replacing fridge
Greetings all,
I tried a search for this answer but had no luck.
I have reached the end of my patience with the Dometic fridge I have and the problem that seems to be unfixable.
I have found a mid size residential fridge that will fit in the space with some slight modification.
It's in a slide, so I have the two vents that I will need to do something about once the residential goes in.
Those of you who have replaced your fridge with a residential, in a slideout, what did you do to seal the vent holes? Or do they even need to be sealed up?
Any guidance would be greatly appreciated.
  • i sealed inside the lower vent door openings, using Alu heat duct tape
    i left the top vent AS IS
    i remove the lower door, for dusting cleaning, and checking the fridge retainng brackets
    or occasionally to use the inverter powered outlet for some tool
    so i don't need to start the generator
  • Find out what the clearance requirements are on the new fridge. I will be replacing with residential myself some day.
  • Depends on where the cooling tubes are. Some are in the side behind sheet metal - those you should leave the vents open.
    Some just vent into the living space from underneath. Won't really matter much what you do with the vents with those.
