grizzzman
Jun 28, 2016Explorer
Darryl&Rita wrote:grizzzman wrote:SFVdave wrote:
I see most route their solar cables down the fridge vent and do so on the side opposite the flue. Is there any concern for the amount of heat generated by fridge, especially on a HOT sunny day. I was told the heat will add resistance to the cables and they will deteriorate quickly and can cause failure of the cables, panels or controller.
Any thoughts?
I used PVC water pipe to protect the wires from direct contact and heat. I had no issues due to heat.
Good luck!
PVC has a lower temp rating than a good quality (temp-wise) wire. Keep both of them away from the flue. Also, being in a conduit lowers the temp rating of all wires vs. open to air.
Well if you read the OPs first post the flue info was known by him......
:R
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
