westend
Jun 29, 2016Explorer
I can't remember the source but there is a terminal block made for fridge vent installations. It attaches to the vent base and wires are connected at that block. If pulling wires directly from roof top to controller, a grommet is the easiest and there are a variety of them made.
Home Depot sells these Box entry fittings that are weather-proof. I used one on my roof top combiner box. It accepts two MC4 wires. I put some caulk on the entrance just to make sure everything is water tight. If you're able to make a hole in the fridge vent base, this fitting will be all you need and it is metal so won't be breaking or deteriorating from heat or UV.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
