RobWNY
Sep 21, 2019Explorer
cannesdo wrote:
Actually...RobWNY...in the video he was holding the element removed from the heater without any wires on the screws when he tested it. Do I need to remove the wires and remove the element before testing it with the multi-meter?
I'm not sure if the element needs to be removed to test Ohms. I've only checked mine after taking it out. It's probably a good idea to do that anyway. While the tank is empty, you can also look at the Anode rod to see if it needs to be replaced also.
