pconroy328's avatar
pconroy328
Question about the output from my DIY Solar
So I could use a "shove in the right direction."
My Solar is all DIY. Two 100 watt panels, an EPEver 30A MPPT controller. One group 27 (for now).
It's working. It's keeping the battery charged.
But I don't think it's working right, or even close to optimal.
The first 100 watt panel is two years old. I started with it, just one 100 watt. I added the second 100 watt panel a month ago - wired parallel.
Wire from panels to controller is 10g stranded from Home Depot.
Thing is I just started watching the power output recently!
Today is FULL SUN, No Clouds, Noon in Denver.
I'm getting 30 watts.
Looking back at historical data for the week, the best I've ever done is 85 watts from the two panels.
Does that happen?
I *am* plugged in and the battery is fully charged.
Is that what's happening?
The controller is smart enough to dial down the wattage since it's not needed?
If I unplugged and discharged the battery - will I see the controller display more wattage from the panels?
(As I'm typing this, I think I'll try that now. Unplug.)
But I'm a bit confused and wanted to hear from some of you.
Thank you!!!
  • Sounds like only one panel is working. The controller will dial back the charge rate as needed. I don't know if your controller shows what's coming in from the panels.. that would be a clue.
    I've had two panels fail in 15 years. They show burnt spots, black or brown, on the front of the panel. They're the aluminum ribbons that connect the cells together. They get hot, so you want want to check for hot spots.
    You can check each panel with a voltmeter, or, temporarily wire in series to see if the voltage doubles.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
