time2roll
Apr 26, 2017Nomad
If you are planning on plugging into a 20 amp GFI I believe it will just trip due to the shared ground and neutral bond. Or will you plug into a 50 amp connector?
I assume one air only works on the 30 amp utility power and both airs will run from the generator?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
