cajundood
Oct 31, 2017Explorer
ktmrfs wrote:cajundood wrote:
Is this item basically the same thing as the one made by micro air.....just without all the fancy housing and labeling? Ebay item 131690262156
highly unlikely that it is anything similar to the micro air easy start.
these conditions required that I parallel my honda's. and even then it usually wouldn't start if they were in eco mode.
installed micro air easy start.
I did some rotor current was measured with a NIST traceable clamp on current probe capable of capturing 10ms or narrower peaks.
those parallel devices.......do they work well? do they require same wattage generators on both sides?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
